TwinTurbo.NET: Nissan 300ZX forum - No, after it is bolted down and the belt is around the
Tanley
on April 09, 2015 at 4:17 PM
Hold up...
posted by Goldchocobo
on April 09, 2015 at 04:07 PM
pulley I remove the stopper bolt. Not that it matters much, the tensioner never extends out to 4mm where the stopper bolt is set before installing the tensioner.
Tight timing belt tensioner.
Tanley
21:39:48 04/08/15
Re: Tight timing belt tensioner.
Goldchocobo
22:31:11 04/08/15
I think I wrote that wrong, it was 4mm out of the box with
Tanley
04:41:53 04/09/15
Hold up...
Goldchocobo
16:07:30 04/09/15
No, after it is bolted down and the belt is around the -
Tanley
16:17:12 04/09/15
I see exactly what you're doing wrong here.
Goldchocobo
16:19:11 04/09/15
Interesting, the FSM states to adjust the tensioner to the
Tanley
16:55:44 04/09/15
Sorry, I was under a misunderstanding.
Goldchocobo
17:43:21 04/09/15
tumevain
10:02:48 04/09/15
Yep, tried that multiple times, no change. (n/m)
Tanley
12:20:28 04/09/15
There is a small amount of play in the bolt
xpwarrior
18:15:05 04/09/15
Hmm I did not know that, I'll loosen it up and retighten
Tanley
19:49:20 04/09/15
So I finally got it to 3.5 mm
Tanley
19:50:16 04/10/15
Which manufacturer made the OEM belt you are using?
xpwarrior
21:44:44 04/10/15
It's a Unitta belt. I was thinking about doing that, but
Tanley
22:52:51 04/10/15
